So this week my car had a "Cranks, but no start" problem. I changed out spark plugs and checked for codes and was running all over looking for problems and finally my buddy asked me "Do you have fuel pressure?". I immediately face-palmed myself
So I went ahead and started checking all the wires and relays and fuses, when I came across some articles about how finicky the stock Fuel Pressure Control Unit (FPCU) is. So I went ahead and jumped power and ground to my Fuel pump to make sure that the pump itself was not the problem. My Fuel pressure reading immediately jumped up to 50psi! At this point, I did not even bother to check any other wiring, the FPCU must be the problem.
I am setting this car up for E85, so this is not really a big deal. I'm planning to upgrade the fuel pump and get an aftermarket Fuel Pressure Regulator (FPR). I'm going to wire the Fuel pump to run near max anytime the car is running, and just let the FPR run the excess back to the fuel tank.
I was wondering what some suggestions for aftermarket brands of fuel pumps and FPR's are? Keeping in mind that I may need to run up to 1.5 or more times the stock fuel pressure to run E85.
Any help would be much appreciated!
