z32 fuel filter on a kae quick question...
zer0faith
Car: 2004 Saturn Redline , 2001 Honda Accord v6{saphire}, 1990 S13 RIP :(
OK, so I keep reading that you can switch out the stock fuel filter for a z32 one so my question is this..
Do i have to modify anything like getting a walbro fuel pump before switching them out or is it just plug and play?
I know It's a noobish question and I tried searching but I just wanted to verify. thank you
Thamm
Car: 2001 Lexus IS300, 2003 Toyota Matrix, 1993 Honda Civic
No mods. Plugs right in.
TroubleBound
Car: 1992 240SX Hatch
Thamm wrote:No mods. Plugs right in.
zer0faith
same thing with the maf?
nissanman04
Car: '90 240SX, '95 Subaru Legacy
zer0faith wrote:same thing with the maf?
No, you'll need something to calibrate the MAF sensor and ECU like an SAFC or ROM tune. Unless you are going turbo, there is no need to change the MAF sensor.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
I concur....
hotrod240sx
Car: 1991 Nissan 240sx SE Hatchback with Hicas
its just as easy as undo the other filter and install the new 1, i did mine not long ago. the original bracket is even holding mine with surprised me a little but it does. as far as the maf like they say there would be tuning involved.
zer0faith
ok. ya i am thinking about doing the maf swap since i am getting the motor ready for boost. i.e. full rebuild have any of you heard about using and ls1 maf? just curious and thank you for the help so far!
heartofaskyline
Car: 1992 hatch, 1993 sr20 coupe
never heard of using an ls maf. i have heard of using a cobra/lightning maf but it all depends on which management you use. as far the the fuel filter, does it really make any difference at all? i mean im running a freaking chevy 350 filter on my car. a filters a filter
zer0faith
nice.. must be a rumor without substance i guess haha
biggie
And the Z32 FF is not better than the S13, the reason a lot started using the Z32 FF was it was cheaper than the S13, I'm not sure that's still the case.
And never heard of anyone using an LS1 MAF, Z32/Cobra/Lightning are the only ones that are common and you still need some form of correction to use those (ECU or SAFC/other). I'm using Cobra, but have ECU tuned for it.
zer0faith
gotcha. so i should just stick with the stock ff then
biggie
zer0faith wrote:gotcha. so i should just stick with the stock ff then
Check prices on both, get which ever is cheaper.
zer0faith
will do thanks!
