Z32 Front & Rear subframe swap to a '90 240
Loch Ness
Car: ThE BeSt oF NiSsAn
Will a 300xxtt front and rear subframe swap into '90 240sx.I'm working on dropping a 300zxtt m/t.It seems that nobody has tried this in order to fit this motor in.i know that the rear struts will need some modification, but I'm not sure about the front.I am looking into a wide body kit for the solution.
180fan
Car: 89 fastback
no. the z32 is wider at the rails where they bolt up.
Loch Ness
do u know how much wider the z32 is to an s13
rudeboy
Car: cars
aprox 2"
Loch Ness
will the rear diff from a z31 or z32 fit on a 240sx
