z32 front calipers on the sohc rotor
j1rm
Car: 94 Accord auto. 90 Z32 (in the works)
do i need to swap out to the 5 lugger rotor in order to use the z32 calipers? can i just add the front calipers with out the rotors?
allenms240
Car: 1991 Nissan 240SX
Nope, the z32s use a bigger rotor.You can buy rotors on ebay that come drilled for four and five lug, they are also drilled and slotted. That's why I got. About 100$ shipped.
P_856
Car: s13
or you can re-drill the bolt pattern from 5x114.3 to 4x114.3
j1rm
thank you guys. im assuming it will bolt right up to the holding bracket for the 240s caliper. thanks again. what about the brake hose? i used to read about having to change it but now no one seems to address it. is the 240 hose fine for the tt caliper?
P_856
Car: s13
it bolts right up you will need the stock 300zx lines or after conversion lines read this it will answer all your questions http://importnut.net/300zxbrakeswap.htm
