Terrorinc17 »
https://forums.nicoclub.com/terrorinc17-u50048.html
Wed Sep 03, 2008 10:11 am
1. Check all your fittings to make sure they are tight.
2. Top off the master cylinder.
3. Make sure each caliper is on the correct side. The BLEER must point UP!You can bleed them for 5 years and will get a ton of fluid out of them, but if the bleeders are pointing down you will never get a pedal because you will never get the air out of them.
4. Bench bleed the master before bleeding the calipers. Make sure the front of the master is pointing down. This will allow air to travel back twords the outlets on the master. This remoces all the air out of the master.
5. Hook up your steel lines.
6. Start at the right rear. Pump the pedal 3-4 time to build pressure, hold it to the floor and release the bleeder. From now on all you need is 1 push to the floor and hold while opening the bleeder. No need to "Pump it up".
6. Then do Left Rear, Right Front, Left Front. After about 4-5 bleeds at each wheel make sure you check the master. Don't let it run out of fluid.
You should have a rock hard pedal. If not check your hoses to make sure you have no leaks or buldges in the rubber.
If your still having trouble try putting a vice grip on 2 of the lines to see if you have pressue.
It sounds to me like you have air in the system due to the master running dry or the caliper bleeders are pointing down.
If all else fails replace the Master.
Good Luck.
