z32 front brakes on 240sx
BoBa524
Car: 1995 Nissan 240SX SE
I looked around and i can't really find any specific information on the swap. I saw a lot of random 26mm and 30mm here and there but thats all. i want to buy everything new from a store so i want to be able to say i need 19## nissan 300zx/no turbo/turbo/anything else?
Which set up is everyone using or is better for the s14?What year 300zx and what options it had?
What else is needed except for caliper/rotors/pads?
Any good install write ups?
thank you,BoBa
namwons_240
Car: 97' 200sx ser
youll need conversion brake lines. dont think u can get new ones but i could be wrong. just go to autozone for some remans, they can give u price, part #'s and such for all the z32 brakes and rotors.
BoBa524
see again jst z32 and thats it no info.
i read a good article on here that you can use 300zx lines (steel ones recommended)
looking for
BoBa524 wrote:19## nissan 300zx/na/turbo/anything else? Which set up is everyone using or is better for the s14?What year 300zx and what options it had?
240TweakerNewbee
Car: 1989 Nissan 240SX
I did mine last month:http://www.rockauto.com 1992 300zx Twin Turbo fully loaded (aluminum 30mm), get rotors for the same ,most expensive you can find ($50 each or the like). They will sell you remanufactured.Only do this if you have a 5lug conversion already.Get a 300zx master cylinder too (get that from Ebay, and make sure its a 300zx MC for a 240sx)of course you will need steel braded lines 300zx style (enjukuracing.com or ebay), and a rotor for the rear can come from a 5lug S14.. plugs right in with no changes to the rear break calipers.
---This break setup is by far the best thing ive done to the car since the SR swap But dammit all that is friggin expensive$$$ $$$
BoBa524
holly crap
THANK YOU
