z32 for vh41de
chance42013
Car: 97 infiniti q45
i have a 97 vh41de looking to mate to a manual would the z32 be the best option first import vehicle i have ever owned want to release the power have designs for a twin turbo set up just need to know if transmission will work
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
well its not gonna bolt up so youll have to make your own adapter plate (VH45 plates wont work) but the clutch and flywheel still will bolt up...
Infinitiguy19
Car: 1993 Infiniti Q45 188580 Miles
1994 Infiniti Q45a 240000 Miles
I thought that the VH41DE and VH45DE shared the same block and *transmission. So if thats the case it would work/should work.
*1994-1996 Only
elwesso
2007 BMW M Coupe
all 90-01 Q45 use the RE4R03A transmission however they have different bolt patterns..
note that nissan pathfinder, 300ZX twin turbo, etc etc use RE4R03A.. Same basic AT with different bellhousings and other minor differences.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
And the RE04 mated with the VH41De uses a different transmission filter kit than the RE04 mated to the VH45DE.
VIP Q45t
Car: 1994 Q45t
Sorry to thread jack.
But would a z32 motor using the g50 transmission be able to work in a g50?
Infinitiguy19
Let me see if I have this right. You want to put a VG30DE(TT) in a G50 Q45 with the OEM G50 transmission?
Why on earth would you want that?
Let alone a VH41DE with a 5 speed when you could use a VH45DE. Or is it because you want to be the :"First" on NICO.
No offence is meant by this post.
elwesso
2007 BMW M Coupe
VIP Q45t wrote:Sorry to thread jack.
In theory, if you want to fabricate everything to make that work for the same HP and add probably 200lbs and make it more front heavy than it is.
if theres a will, theres a way man.
VIP Q45t
Car: 1994 Q45t
i'm just trying to explore my options. and i figure nissan engines would work better with this car, instead of toyota engines. although i wouldn't mind a 2jz. lol!i want to swap my motor out for something else and IF possible and I would like to keep it automatic.
shoot me some swap ideas if you guys have any. but try to stay away from rb's, because the parts are too hard to come by or expensive.thanks.
Modified by VIP Q45t at 5:16 PM 8/10/2009
elwesso
2007 BMW M Coupe
i dont want to dwell on this because this is not the OP's topic of discussion, but why do you think people are taking their TWIN TURBO V6's and other "sweet" engines and putting in VH45DE's???
Because VH45's are amazing.
VIP Q45t
Car: 1994 Q45t
elwesso wrote:i dont want to dwell on this because this is not the OP's topic of discussion, but why do you think people are taking their TWIN TURBO V6's and other "sweet" engines and putting in VH45DE's???
not mine. it has some kinda bug that i can't fix. so i just want it out, plus i wouldn't mind having a turbo'd car for a change.
but thanks.
anyway...back to the op's topic.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
VIP Q45t wrote:it has some kinda bug that i can't fix.
Might try posting up the symptoms and maintenance history in IOM per the sticky there.
Much easier to diagnose a non-turbo engine.
chance42013
thanks for responding i have a 97 q45 with extra motor and transmission going to put them in a buggy i heard that the bottom end of a vh 45 will fit the vh41 besides that is the vh41 any worse than the vh45 or better for that matter
elwesso
2007 BMW M Coupe
The VH41 out of a Q45 is definitely not as good as the VH45. Not as much of the cool stuff like the main bearing girdle and stuff like that... Some other stuff too..
Depends all what you're wanting to do to it. You could run a VH41 in stock form balls to the walls all day and not really hurt it... which would happen in a buggy
chance42013
would it be worth getting my hands on a vh45 or would the 41 be better for the buggy when i get done with the motor it will be bad twin turbo in buggy first then try to fit in the q
elwesso
2007 BMW M Coupe
Well the VH41 with OBDII is going to require a standalone ECU to tune and will definitely not be as easy to modify...
If your going for mad power, I'd go with the VH45..
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You need to visit the VH/VK Forum.
