z32 ebrake...
nightsauce
Car: 1991 Nissan 240SX S13 hatch RIP
1992 Nissan 240S S13 hatch :D
i just got my ebrake setup and realized that its from the 2 seater z32. I only read this once, but I heard people used the 2 seater cables by snaking them through the subframe. I only read it once so I was wondering if its been done...
nightsauce
no dice? i guess i'll just have to bolt it up n try :|
Spiffy240
Car: 1992 White 240sx Fastback SE
ive read that the 2+2 ebrake cables are longer then the other 300zx cables and they can run through the subframe hole.
I believe I also have 2+2 cables, but you have to make sure that rubber boot sits well in the subframe hole or else the cable will get caught and not be at full tension.
nightsauce
im headed outside now to see what I can get done..
duffman1278
Car: 89 240sx Hatch, the wildcats!
It can be easily done. I ran mine without a problem.
