BigTDogg (MA) wrote:The JWT (or any other off the shelf (OTS) tune for that matter) will only change your K value for your larger injectors, or the number of MAFs you are running. It's not a tune as much as it's a parameter edit to get the car to idle and drive. A tune, a real dyno tune with A/F measurement and knock control/monitoring will give you the most potential from your car, safely.
Ok so you say dyno tuning is a must. My only concern is the factory ECU. If i wanted dyno tuning i would need an ECU that is adjustable/tuneable. Correct me if i am wrong but the factory ecu is not. Therefore i would need $2000 worth of standalone, which i am not against, but for now its not on my priorty list.
Im reviving this thread as the VG has to come out very soon. Seems i have possibly broken a piston skirt...Once warmed up it developes a really nice knocking noise abouve 1500 rpm. (Sarcasm on the "nice"). That being said its been sitting for about a month, while ive been situating a daily. Now im happy with the daily and back to focusing on the Z. Also on a side note cylinders 1-3-5 have 150psi cylinders 2-4-6 have 125psi, both sides each cyl. within 2-3 psi of eachother. How is that for interesting. Oh and of course an obnoxious lifter. What a trifecta, lol.
I don't care to try and diagnose the knocking noise over forums, thats not the intention of this post. I will simply tear the engine apart and find what broke and upgrade it. Along with a full rebuild. Im hoping i dont have to overbore, but i know i most likely will.
My plan as of now: Pull the motor and tear it apart.
Block:
Weisco forged pistons
Stock rods
overbore .020
Deck the block
new bearings/ thrust washer
polish crank journals
ARP main studs
hot tank
De burr
balance rotating assembly
Heads:
pressure test/ hot tank
deck the heads
valve grind
valve guides (Only if needed)
Valve stem seals
port match (gasket match)
rebuild lifters, replace as necessary
ARP head studs
External:
standard 120k with oil pump
z1 550bb kit
Either detachwerk or nismo injectors (If the DW are redrills please let me know, also do i want 550cc or larger?)
Thats the Jist of where im at. Hoping this build will net between 450-500whp. Im in need of your imput as to my plan, is it adequate, am i missing items, any other machine work i should look into..Ect Ect. Im still new to the VG and dont know about ALL the "quirks". Id prefer to only build the VG once (tho i understand their are too many variables), id rather do it right the first time on internal work.
So far im looking at around $5,000 worth of parts (as most of you are aware, its not cheap) and i have no idea what the machine work is going to cost, but i would prefer to pay extra for proper machine work, IE someone who has knowledge with our technology and not the 65 year old man who runs a machine shop that knows eveything in the world about SBC motors..Their is miles of differences between the 2 and what works on 1960's technology doesn't really apply to our technology, this i understand, which is why im willing to pay a little exrta for proper maching. Because as stated earlier: im building a race engine, however since its drifting, im not worried about .010's of a second, more so just RELIABLE power.
Thanks
