z32 cluster ever considered
Omni
I might be able to get a z32 cluster and i was figuring if i was getting it for free and it was already calibebrated for a 6 cylinder iw would be nice to use...but what hell would i have to go through to make it fit in my s13 and how would the wiring work out....anyone every tried it and done it i am interested in trying this
Omni
i have search the internet high and low and have found nothing...anyone think this is possible?? i would really like to try it on my car but scared of messing up
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
I did it back in 05 and be prepared for a b**** of a time. There were a small number of cars that had the correct gauges that would hook up to a 240sx board but there was still an a** load of modifications to make them fit. The 300zx gauges are actually 1/2 inch plus taller. I used the 300zx gauges in a 240sx cluster. Im attaching pics of my test fit. I did the odometer cutout and switched the needles after to all 300zx orange after the fact.
DustinZ
DustinZ
http://s662.photobucket.com/albums/uu34 ... MG0940.jpg
[urhttp://s662.photobucket.com/albums/uu341/midnightauto1/?action=view&current=CIMG0940.jpg#!oZZ2QQcurrentZZhttp%3A%2F%2Fs662.photobucket.com%2Falbums%2Fuu341%2Fmidnightauto1%2F%3Faction%3Dview%26current%3DCIMG0939jpg.jpgl][/url]
Omni
hmn i might do what u did and put the cluster face in the 240...that would probably make my life alot easier...but the reason i wanted to do it though is because the z was already a 6 cylinder maybe the board would have already been readying right for the rb..??? AND IF THAT IS UR RX8 I LOVE U MAN
HxC_Nismo
Car: '98 Nissan 240SX SE R33 RB26DET
'07 Nissan Titan SE
'05 Toyota Corolla
very clean conversion dustinz, im impressed. you should do a write-up on that conversion
DustinZ
Trying to get time to do the r33 cluster in my other s13 rb25 right now. The 300zx is a pita to do. Oil pressure works and with it has the odometer cut in now with trip. If I can find another 91 z cluster and the gauges are right I might do a write up. Most of the 300 clusters are not usable due to the gauge mounting on the back. Only that one 91 cluster I found would work on the 240sx circuit board.
The rx8 isnt mine. It belongs to Hinson Motorsports. We did a ls1 swap in it. Pretty fun car now and puts out a lot more than the boosted renisis.
DustinZ
Omni
u did a bueatiful job on the cluster sir...will it be hard for me to put in the stuff u did and get them to work?? i am gonna attempt it tommorrow hahaha wish me luck sir
DustinZ
You have to cut a huge amount of material from the 240sx back housing and then use a heat cun to reshape it. I also had to heat and reshape the bezel to clear the oil pressure gauge.
DustinZ
Omni
lol i left out the oil pressure and ghetto fitted it hahahah but for some reason i think the previous owner f*** up tHE RPM signal for the dash cause MINE IS NOT WORKING
DustinZ
trace the wire to the dash plug and if that beeps out check the engine harness to the ecu.
DustinZ
Omni
ok than u sir will do
