RCA »
https://forums.nicoclub.com/rca-u54941.html
Fri Jan 22, 2010 2:35 pm
Not sure what it takes to use Z32 rear brakes on an S13 but I am sure it would be easier to just use replacement S13 parts. I bet your car is stock and you use it as a daily driver. The S13 has a specific brake bias that calculates how much force is used between the front and rear brakes. With the new Z brakes installed you will probably need to change the bias so this way it doesn't give to much clamping force to the rear. This could cause your rear tires to lock before your front tires. There is a lot to consider hear. Also read up on the science behind braking.
It isn't as simple as adding parts that fit together... they need to work together.
I answered this because it was an unanswered topic so if I am totally off then I appologize. I just wanted to get the ball rolling...
