Z32 caliper question
Florida240sx
I searched and couldn't find the da*n thread. Wanting a set of super advans. Will 16" super advans clear z32 calipers? I had the damn thing bookmarked like a year ago and now that i'm getting around to brakes and rims I can't find it.
McRussellPants
Car: 92 240SX
Super Advans blow.
They weigh a ton and still bnd easy due to a naturally bad design.
But yeah, they should clear Z32s unless your getting something obcenely wack.
jr_ss
Car: 95' S14
It depends on the offset. If they are +30's or so they should clear just fine. However anything lower than that and you might have to run a spacer.Besides I know you want the flush look anyways.
nismofly
Car: 89 Nissan 240SX Hatch
if its those 16x7's youre looking at, itll probably be close, depending on offset
Florida240sx
I don't care if I need a spacer. I just need a set of rims that will allow my z32 calipers to work. any 17" work?? 16" with 30+ offset??? I've forgotten everyything I knew about z32 caliper and rim set-ups.This car is mainly for drag.Don't need to take an accountant for drifitng.
