I think so. Front one is okay, but rear one is like $180 each something like that.Hijacker wrote:They should still be available through Nissan I would think.
Oh!! Inside... Yes, outside where it touch the seal really matter. If you are anal, you can sand blast inside of pistons. Or use a Dremel to clean it up like I did.Black on Gold wrote:They look a little rough with the rust inside the piston but from what everyone said, as long as its not in the seal/boot area i should be fine.
Actually, I replaced a couple of real bad ones.Black on Gold wrote:^^ Yea from the write up yours were clean...that why i may have thought you got new ones with another rebuild kit
