rroderiques77 »
https://forums.nicoclub.com/rroderiques77-u82632.html
Sat Jan 24, 2009 1:56 pm
well, i say u have to spread the pads apart by prying before u can install the tool, cuz removing the caliper bolts might have been too much work for u. u already think spreading pistons is alot of work. just trying to give you the fastest/easiest way buddy. i know you can remove the caliper and slide it off the rotor to install the spreader tool....but im trying to save you "work". And if you know all this stuff, why are you asking? and yes, i too believe you should use the right tool for the job...thats why i have a piston spreader....it sounded like you were looking for a way around using the spreader tool... and you CAN pry gently to spread it and NOT mess up the caliper bro. just be gentle. i do it every day...today was a Tundra(notice how i still use the pry method even though i have a spreader? sometimes its easier, sometimes its not. today was simple pad slap, so i pry until i have room for the spreader. then i use it....no need to remove caliper;'))
