z32 caliper clearance question
KoukiS14via
Car: 97 240sx
Hey guys, I'm running Volk GT-Ns 17x8 in the front with a +44 offset. Does anyone know if this will clear Z32 30mm calipers? Need to get my brakes done asap leaking brake fluid so I figured I'd do the whole front/rear Z32 TT conversion. Also, with or without spacers and how thick if needed?
Thanks in advance!
94_240sx
Car: 94_240SX
GT-N Looks like this. Right? It should clear it. Worst case, you might need 5-10mm spacers. +44 is not a good offset for S14.
KoukiS14via
Car: 97 240sx
Yup those are them, unfortunately they came with the car so I couldn't chose offset... Thanks! Is that your car? What's your offset and what size spacers did you use?
