Z32 Caliper Clearance on S13
stanzaboi
Car: s13 coupe
Hello everyone. I currently have 17x7 Racing Hart CP-035 rims on my '92 with the 32mm 300zx calipers and a 5mm(?)spacer. I'm ordering some 18x8 exel ennios, imitation Axis Muse, and was wondering if I will still need the spacers? Also, I currently have Kuhmo Ecsta Supra 712s on my 17"s right now and love them. Would the 18" Kuhmos be any different? Thanks for all the help.
1991S13
Car: '91 240sx Coupe, '00 QX4 4x4, '02 Sentra Spec V
You will most likely still need the spacers. If they will not clear, you could use Q45 hardware. They mount the same as the 300zx units and are the same diameter rotors but only come in 28mm. The Q45 uses a 2 piston slider caliper, and the pistons are located on the back side of the caliper so the front side has nearly the same clearance as your stock 240sx brakes did.
hannibal
Car: Red Line to Glenmont
I love the Axis Muse!! I wish someone made a 17" copy...
stanzaboi
Car: s13 coupe
I believe exel makes a 17" copy, not to mention that it is available in a 4x114.3 bolt pattern as well!!!
N.O. Accorderz
whatcha doing with you old 17s? i see your car once in a while at uno check out nostreetracing.org its local
ayjay
what offset do the exel's come in btw? i can't find any info whatsoever on the exel's and stupid online retailers never mention the offsets... prolly +40
stanzaboi
Car: s13 coupe
what do you drive? maybe if seen you too?
N.O. Accorderz
i drive a red fastback
Dirtylou
Car: 1991 Nissan 240SX RMS13
What are the ideal wheel specs for an s13 with z32 calipers?
