Z32 Caliper Brake Line Torque Specs
positron1
Car: Project: 1993 Nissan 240SX Coupe SR
Daily: 2010 Honda Civic Coupe
Does anyone know the torque specs for the brake lines on the rear Z32 calipers?
S14-KOUKI-MONSTER
Car: '97.5 Kouki s14 le w/Kouki s14 sr & '03 Xterra w/6" lift on 33s
What were you going to use to torque them with? You have a flare nut wrench or crow's foot adapter to use with a torque wrench? I've never once seen anyone torque brake lines, although I suppose it's possible with the right torque wrench adapter.Just make sure that they're tight, but not too tight. After you bleed them, pump the pedal to build pressure, and hold down the pedal for a minute or two while a buddy looks for leaks at the lines.Do you have the aluminum caliper's? If you do just be careful not to over tighten, and strip the threads out.
