just wanted to get some insight to z32 brakes with ABS
my s13 has ABS and i am considering getting a set of z32 fronts. what i am worried about is if this will mess up my abs system or anything else. i dont care that much about whether the abs works or not, but i dont want it kicking in when it shouldnt either
i have googled this a fair amount and have tried my best to search on here. so far i dont THINK it should be a problem, but i have also seen some things that say otherwise:
"In short the ABS system on your S13/S14 will no longer properly work. During the design process of any vehicle equipped with ABS the ABS controller is programmed with stock hardware limits such as the maximum deceleration, stock wheels, stock brake system (thermal capacity, rotor size, braking split, the engineers even factor in such variables as line expansion.) The ABS controller expects the physics of the vehicle to remain constant, as in it won't learn if you put larger wheels on the vehicle much less the calipers/rotors/master cylinder.
For further reading I would suggest this article. Also I don't mention anything about Traction Control Systems or anything advanced like that because the S13/S14 aren't equipped them. But
basically if the ABS doesn't function correctly it will create issues in the other more advance systems."
http://my240.epijunkie.com/5_Lug_and_Z3 ... ersion#ABS
thats the site where i got the quote from. seems sort of funny that it says if the ABS doesnt function, it will create more issues in "advanced systems" what the hell is advanced on a 17 year old car? not like i have traction control
can anyone give me a bit of insight into this? perhaps someone with an s13 with abs and has done the swap?
