Z32 brakes to s13 vert?
Xx_Jeff_xX
Car: 1993 240sx convertible
How do you install the 300zx front calipers onto a 240sx? is it just bolt on or some work is required?can you use stock rotors or you have to get Z32 rotors?
leonelrr
Car: s13,s14, z32TT, YZF R6 None of them work nothing to brag about
I see you are new to the site.. So i am going to answer your question.. But please before you post a question make sure you use the search option.. Or prepare to get flamed!
Your rotors are smaller and thinner so " NO you can't use them"If you don't want to do the 5 lug conversion, then you can get your rotors drilled for 4 lugs as well...
Then depending on your wheel offset, you might need to run spacers, extended wheel studs or buy different wheels..
biggie
Full article including bmc and rear swaps:zerothread?id=426226
94_240sx
Car: 94_240SX
biggie wrote:Full article including bmc and rear swaps:zerothread?id=426226
Links are all broken.
Here's actual thread.zer...-pics
