Z32 Brakes
R-Factor
Car: 91 240sx SE
Does anyone know if the stock, 15" 7 spoke 91 s13 rims will clear the stock 300zx rotors and calipers?
Hijacker
Car: '92 240sx Convertible
'94 F-150
the 26mm calipers will. the 30mm calipers won't.
R-Factor
Car: 91 240sx SE
Which z32 calipers are the 26mm and which ones are the 30mm? Thanks for the help.
Hijacker
'94 F-150
do a search next time. this has been written so many times.
All 91 and up models had the 30mm calipers. the 90 N/A model has the 26mm calipers, and the 90 TT has 30mm
Twinchy
Car: Peg leggin 240sx
do you need to run spacers on the 26mm on the 7 spoke wheels?
Dookie
Car: 1993 240sx Coupe
http://sillbeer.com/s13sewheels.php There were 2 different castings of the alloys, each with a different pattern behind the spokes, that will determine if 26mm Z brakes will fit. Go to that website for reference.
Hijacker
'94 F-150
that only applies to the 93 and 94 models i think.
as far as spacers run, if you have the proper cast wheel, you won't need spacers for the 26mm caliper
Twinchy
well thats a very good link iam going to have to check that out when i take off my wheel.the reason is i bought my alloy wheels from one of my friends. i guess when i have time i check to see if i have the good wheels.just in case i dont what size of spacer would i need?
