z32 brakes on base s14
punkeds14
Car: 1996 s14, 1991 s13
hi i was wondering if it was at all possible to put front calipers from a z32 on my base s14. ive searched for this but found nothing about the conversion on a four lug set up. thanks
senioritis
Car: nissan 240sx 1995 red base model
yes it works. you need to redrill the rotors
punkeds14
why re drill the rotors? all i want too use is the calipers. or do i have to use both caliper and rotor from the z32?
Baron Fel
Car: 1991 S13 onevia
no no it's cool, put the Z32 calipers on your stock, obviously thinner and smaller in diameter rotors and let us know what happens lol
BoBa524
Car: 1995 Nissan 240SX SE
i bought my brembo rotors for $120 and they were predrilled for 4 lug. i have an se model tho
Ligouri Rd
Car: '96 Nissan 240SX
Baron Fel wrote:no no it's cool, put the Z32 calipers on your stock, obviously thinner and smaller in diameter rotors and let us know what happens lol
What he said, it doesn't matter that they are brembos or not. They don't make 4lug rotors for Z32 calipers.
Jdmspooge
Car: s14
Just to clarify everyone's response;
Here's what you have to do to your existing 4 lug set up; 1) take off your 4 lug rotors and throw them out or keep them and use them for target practice for your 357 magnum 2) go buy either 26mm or 30mm (depending what calipers you have) brembo blank rotors for the Z32 3) go to your local machine shop and have them drill the new rotors to 4x114 4) install rotors 5) buy some stainless braided brake lines 6) install calipers, pads, fluid, bleed and enjoy your new setup.
G/L
BoBa524
Ligouri Rd wrote:What he said, it doesn't matter that they are brembos or not. They don't make 4lug rotors for Z32 calipers.
they were pre-drilled by selling company.
punkeds14
thanks alot guys!
