Duce40sx »
https://forums.nicoclub.com/duce40sx-u62837.html
Thu Sep 13, 2007 8:40 pm
You know what CLawhammer, I hated you at the beginning when I first saw your hatch with the SE rims,
BUt after a while, I realized that you and I are quite similar
"Great minds think alike~"
What I did was:
I just criss cross them, So the passenger cable goes to the driver wheel side, and the driver side goes to the passenger side. (Get nice and dirty under the car and switch the two ENDS)
1a. I used the same bracket off the 240sx (the one at the end of the cable which was bolted onto the Stock 240sx caliper), I slipped the 240sx ebrake through that oval hole then I slide the bracket over, and put on the Wedge Clip.
1.B Now I mark (or just EYE") the bracket and used a Hacksaw to cut off the protruding excess.
1.C. Now I used a VISE grip and gripped the Bracket onto the lower arm. (I USED MY LINCONL MIG WELDER, TACK WELD, TACK SOME MORE~)
1D. Instead of cutting the 240sx cable "Stub" off the end of the cable. I just left it there.
2. From the Ebrake line (From the back of the Dust shield, I cut the 300zx cable about 10 inches (Just for assurance, thinking I can always trim it if it's longer, ***Better longer than short***
3. Instead of using the outer 300zx sleeve at the bottom. (I cut about 6 inches off the top and used the Top of the sleeve with the "stubby bracket" This way, the 300zx cable would have a nice End with the "Rubber Accordion Dirt protection grommet."
5. Now I used the 300zx "cable sleeve bracket (that brownish-green one). This bracket, with a little, twist~ I bent it down and used the sway/stabilizer bar bolt and nut to tightening down.*** you must drill the hole a little bigger for this braket to go over the bolt. I used a closed end Bolts which i had laying around and tighten it.
****I used 2 "U" clamps to secure the two cables together, and 1 cable Crimp at the END to make sure that these WILL NEVER SLIP. VERY UGLY JOB, but Im paranoid!!! Its very safe~ though. I tested out each and every chance!
The end result looks like this. BUT THERE ARE NUMEROUS WAYS. JUST BE CREATIVE! The WELDMENT is extremel stong I went over it a few times with the MIG to make sure.
I could have just used the 300zx cable and make a custom bracket, (BUT I SNAPPED THE STUB OFF THE 300ZX CABLE~ THUS RESORTING TO THIS METHOD_ WHICH WAS A LOT OF FUN TOO~
LOL WE EVEN PAINTED THE CALIPERS BLACK~~~~ I wanted to do gold, or RED at first but that was too FLASHY and I know you thought abou it too~
Modified by Duce40sx at 12:00 AM 9/14/2007
