Z32 brake upgrade?
miclmurray
Car: 1995 Nissan 240sx
What is the difference between 26mm and 30mm calipers? How can you tell which you have , if you don't know what car they came off of?Thanks!!!
onosqv
Car: '92 240sx Vert
http://importnut.net/300zxbrakeswap.htm#frontbrake
Should have done some searching... if you've searched for z32 brake upgrade at all (i.e. here, google, etc), import nut is like *the* authority on it. Also happens to help you figure out which caliper you have.
good luck.
miclmurray
Thank You!!! That site is just what I needed. I'll use it as first from now on. I'm still new to all this. Again thanks. Michael
