dan222000 »
https://forums.nicoclub.com/dan222000-u59798.html
Sun Nov 09, 2008 4:44 pm
I believe I have 30mm caliper and 30mm rotors. This is the second set of Z32 rotors and calipers I've had. The problem isn't the diameter it's that once I bolt on the caliper it presses against the rotor not allowing the rotor to spin freely. The rotor rubs against the caliper. The fron of the caliper rubs the rotor and the back of the rotor is clearly away from the caliper. I have tried to sandwish a washer beteen the caliper mounts and the upright to bring the caliper out (forward) more and this has worked before but the washer had to be an exact thickness or I have the same problem. I have asked a several friends that have the Z32 conversion on there S13 and they have said it bolts up but I didn't know if there was a differenct in an S14 or if my car being an automatic made any difference.
