Z32 brake upgrade problem
chaosli
Car: 89 nissan 240sx coupe FTW
99 mazda miata
93 bmw 325i RIP
so i did my upgrade today just to find that i have no pressure at alll after i put everything back togather.
i have the full set up 30mm front caliper, rear caliper, new rotors and pads, 1" 1/16 BMC. bleed about a whole gallon of brake fluid.
so now if i press the brake a couple times it locks but once i let the padel go for a sec it lose all pressure i have to pump to get pressure again. would i need a brake booster.
anyidea on what to do if anyone else ran into the same problem.
BTW i did search and found nothing
93240cooool
Car: 1993 240sx
did you replace the brake master cylinder, oh and bleed, bleed, bleed, bleed.
chaosli
99 mazda miata
93 bmw 325i RIP
yes i replaced the BMC and bleed a gallon of fluid i am sure there is no more air pocket
zeause
are your bleeder nipples on top or bottom?Gotta be on top. I learned it the hard way. bout 3 quarts of brake fluid.
chaosli
99 mazda miata
93 bmw 325i RIP
mine pointing bottom...
n240sxfnatic
chaosli wrote:mine pointing bottom...
They have to be on top or you will never get the air out.
Bumnah
Car: 1992 240SX, black. Bone stock.
YUP, if the bleeders aren't on top you're not releasing the pressure.
Start
Driver rearto Passenger rearto passenger frontto Driver front
FSM says
Driver rearto Passenger rearto Driver frontto passenger front
I do the the other way.
Check very carefully for leaks too.
AZ89two4Tsx
Did you replace the booster as well? Idk, I'm just throwing it out there.
nevertheless
Car: 1993 240sx hatch
1995 Nissan D21
I got mine backwards too Time for switcharoo.
