s13 rear calipers also work as e-brake. If you install z32 rear calipers, that feature will be gone and yes, you need z32 e-brake. Just go all the way. No need to hold back.stevejames3 wrote:is it necessary to do the 300zx ebrake swap when doing the z32 brake swap. this is going on an s13. what are the benifits to doing it or not doing it. pros and cons.
I'm the other way around. Search for a member positonones posts. He has some good write ups on brake and suspension stuff.stevejames3 wrote:im more of a motor guy. im just staring to dive into sus. and brakes.
