z32 brake question...quick answer, cant find in searching
thrasherx89
Car: 90 hatch (91 dohc, tein, z32, ss, injen, energy, b &m)
i searched on google
i searched here
i looked at that technical 240sx page and i cant find a difinitive answer
i got the stock 15" 7 spoke s13 rims with an offset of 40 and i have a pair of 30mm aluminum z32 calipers
will these rims clear the caliper?
94_240sx
Car: 94_240SX
EDIT: SOrry. Will clear 26mm depends on inside design. Check this thread.
zerothread/79500
Modified by 94_240sx at 8:32 PM 9/24/2009
Ghost_silvia
Car: 1991 nissan silvia s13
I believe you will need at least 16" with a low offset or some spacers. Then again you can always just try them on if you got them.
thrasherx89
yeah i saw the pic of the ones that look different in the back
im gonna just bolt it up real quick and see if they will clear lol i dobut it though
94_240sx
Car: 94_240SX
If you don't mind using spacers, you should be able to make them fit.
thrasherx89
how much are spacers?
Ghost_silvia
ebay ones are about 90, but you should get either h&R or get powered by max ones like I'm gonna get. If the brakes clear on top, but the inside of the wheels touch then you should measure for the width of spacers you need.
94_240sx
Car: 94_240SX
thrasherx89 wrote:how much are spacers?
Spacers are bit of headache. You can't use stock studs, so you have to replaced them with longer ones. I run these on mine and I love them. They are hub centric, so perfectly balanced. Or you should pick up used wheel in bigger size. I'm telling you. Suspension, brake, wheel and tire upgrade are not cheap.
http://ichibausa.com/15alwhsp9.html
jeff420
Car: too many to fathom
http://www.nicoclub.com/articles.php?id=207414
found that in the tech section. was very easy to find, hope it helps
