gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Sun Sep 14, 2008 5:22 am
I have just re-read my initial response to your post laid out before me. I was genuinely mad. That seldom happens. So I have deleted that and will try again.While all your questions are easy enough to answer, I will abide by your request. I will take it easy on you, and I will help.Use the SEARCH button. Use: brake upgrade or big brakes or z32 brakes or any such combination in the search field. This is the most covered topic next to exhaust upgrades, how do I do a 5 lug swap, and I want an LSD. Show me that you perused ANY of the information available to you, then if you still have any questions about what, where and how, I will drop a bomb bigger than Nagasaki on you. (a bomb of information that is)There is not a question that you have, not an idea you can think of that has not been asked or applied to these cars. Be mindful of that. If you lack the comprehension you should strongly consider an alternate hobby that will not result in harm to either you or anyone unfortunate enough to get in your way while you drift around town.
