McRussellPants »
https://forums.nicoclub.com/mcrussellpants-u32413.html
Fri Dec 09, 2005 11:42 pm
Meh, it wont make too much of a difference on a lightly tracked 2600lb car.
But, if there is a choice, get the 30mm Aluminums.A) The brake rotors are cheaper for some reason, 30$per for 30mms opposed to 70$ for 26mms. (at least here)
B)You wont need the heat capacity from the Irons so the aluminums would be optimal since they are lighter.
C) You could upgrade to the 350Z rotor if it ever went from a lightly tracked car to a track slut.
