S13 Charlie »
https://forums.nicoclub.com/s13-charlie-u18503.html
Fri Dec 17, 2004 12:06 pm
In short, yes, the MC bolts in.
However...
From what I've heard, you would only want to swap to a Z32 MC (NA or Turbo, I think they're the same) if you had front and rear Z32 brakes, or at the very least z32 fronts. This has to do with the proportioning valve built into the Master Cylinder. It diverts pressure to the front or rear brakes in a different ratio than the 240sx MC. If you have stock brakes, then you should just rebuild your mc, or buy one off someone who's swapped theirs for a Z32 unit.
