gumby74 »
https://forums.nicoclub.com/gumby74-u53716.html
Mon Aug 04, 2008 10:28 am
If you go with the dealership, only one is now available, which I believe to be the Nabco.Of the 2 manufacturers though, the Nabco is easier to install the 3rd flair fitting. On the Tokico, you need to run a small drill bit to eliminate the bubble shaped reccess and allow the flair to sit flush.On the end of the m/c the 1" units will be stamped with a BM-50.The 1 1/16" will be stamped BM-57.
