jr_ss wrote: Ah my bad, neither DOT 3 or 4 should be mixed with DOT 5. As 3 and 4 have heavier bases than the 5. Water could collect between the 2 and cause corrosion in the brake lines and various parts. If you want to switch to Dot 5 it's a good idea to flush the entire system with Dot 5. There really is no benefit switching to Dot 5 over 4 though. Dot 5 has a higher boiling temperature of 54 degrees and that's the only benefit, but who actually plans on getting their brakes that hot? That's why you upgrade, so you can dissipate heat faster. I wouldn't waste my time and/or money to switch to the silicone base fluid over the gylcol base fluid. But do what you want man.
sorry dude, but if you don't know what you're talking about, don't post. some of that info was wrong. no need to add more wrong info if the questions have been answered.
water won't collect between the two because glycol is hydroscopic (i think that's the right word) which means it absorbs water. you shouldn't mix the two because each requires different rubber in the calipers and MC. that and silicon is horrible for passenger vehicle applications.
you kept refering to DOT 5. DOT 5 and 5.1 are two very different fluids. 5 is silicone based but 5.1 is glycol based, like DOT 3 and 4 just a higher boiling point.
Valvoline synpower is fine, it's DOT 4 and it's cheap. no need to spend loads on brake parts and still fade the brakes because of crappy fluid. Z32 brakes will still transfer a good deal of heat to the fluid so it's still worth the upgrade.
Modified by cdlong at 3:09 PM 12/16/2005
