So I finally got around to buying some rotors so I could install my Z32 30mm Alum calipers I got back in February
zerothread?id=228844.
I paid $130 shipped for them, Brembo Blanks (same as rear that I already had) that have been CD/S.
Anyway, everything went together really nice and easy with the only hard part being cutting away the dust shield so the rotors would fit.
So as I first drive the car and start the light break-in and 60mph to 40mph stops to set the rotors and pads I hear a grinding sound. Well I get out to look "because I know the dust shields aren't rubbing". Well this is what I see, a small ring on the outside of the rotor where the pad isn't making contact but it's grinding into the rotor. Well it hasn't damaged the rotor but I'm def not driving around with it like this so I had to park it. I haven't taken it apart either but will get to it 1st thing in the morning.
Any ideas of what's rubbing the rotor?? It has to be part of the caliper or something in the caliper.
See the 1/4" groove on the outer most part of the rotor, WTF???
Here's the passenger side, no problems.
Back set-up for giggles..
Thanks-Jason
