Z32 brake clearance on stock S14 alloys
canadians14
Hey i'm sorry if its been posted before but i've done a quick 10 minute search and come up with nothing.
Will 30mm 300zx aluminum calipers clear stock S14 alloy wheels. The dimensions are 16 X 6.5, 40mm offset. Reason is i live in Canada and they will need to clear my winter rims/tires. I want to avoid wheel spacers if at all possible but am not against shaving the calipers down a little bit if that helps. Thanks.
26mm calipers are out of the the question as well because they are getting to hard to find.
hannibal
Car: Red Line to Glenmont
They fit.
Apparently Silvia K's in Japan use the same 30mm calipers and our same 5 spoke SE wheels.
And I agree about the 26mm brakes being harder to find...
canadians14det
Car: 1996 240SX DE-T
thanks for the help
