z32 brake / 5 lug conversion
michael_grigoras
Car: 1991 nissan 240sx
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
about to do 5 lug and z32 conversion only thing im not sure of yet is if i have to use the z32 knuckle in the rear to do the brake swap or could i just use the 240sx one
Cody240
Car: 1990 240sx SE white with KA24DE
all you need to do is take the hub and e brake assy. of the z knuckle and bolt it to the 240 Knuckle, the have the same bolt pattern and axle hole diameter. Oh and make sure to get z32 2+2 ebrake cables because those should bolt right up.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
ok but do i need to change anything with coilovers because of how they mount?
Cody240
No everything bolts right up if you use the knuckle from the 240 not the z, all you need to do like i said was swap the hub and other stuff onto the 240 knuckle
zooopreme
Car: 1993 240SX (S13)
If your coilovers don't have the z32 lower mounts, make sure you've got those. But other than that, you're straight.
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Parts needed
Loaded calipers
Rotors
Conversion brake lines
loaded Z32 or Q45 rear backing plates
Z32 2+2 ebrake cables, or standard z32 cables routed a different way with a bracket stay welded onto the cars body
Z32 BMC with one of the flares cut out of your s13 BMC and pressed in.
Now you can use OEM s14 or z32 NA rear hubs for the rear 5 lug conversion and
S14 LCA or S13 LCAs with S14 LBJs pressed in
S14 Knuckles
S14 front shock or coil or drill the hole bigger and use the larger S14 bolt or buy the hole spacer kits.
krash
OutToWinPAHC wrote: Now you can use OEM s14 or z32 NA rear hubs for the rear 5 lug conversion and
S14 Knuckles
Couldn't he just get conversion hubs for the front? seems easier?
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
yeah, but unless they are real Ichiba the bearing suck
krash
Very true, and even then I hear some stories every once in a while. Conversion hubs + OEM bearings are the best I think.
TheRealNap0le0n
Car: 1998 q45
i did the conversion hubs with the $150/pair of ichiba off ebay.... a year later i need bearing but im very satisfied cuz now i can just buy oem s13 bearing... easier
TheRealNap0le0n
Car: 1998 q45
you have to make brackets for the ebrake cables to attach to the body as well
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
ok so i have bought the front and rear hubs front ichiba got rotors and the calipers off ebay all 4 for 300 so all i need now are pads new lines and e brake cables oh shims and hardware kit to rebuild them
Cody240
Now i thought you could use normal z32 bake lines if you didn't by stainless steel one's
TheRealNap0le0n
Car: 1998 q45
Cody240 wrote:Now i thought you could use normal z32 bake lines if you didn't by stainless steel one's
you need the conversion lines
Cody240
what is the difference?
TheRealNap0le0n
Car: 1998 q45
the connection
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
people say you need conversion lines, but I have used stock s13/14 lines with no issues, just remove the nipple off the caliper..it will work..trust me, also R32 e brake cables work with no mods, bolt right up to stock e brake mounting points.
TheRealNap0le0n
Car: 1998 q45
the problem i had was the cable itself was too long... and if you are doing the Z32 conversion why not just spend the $50 on nice lines
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
i might check out the r32 ones sounds simple but before i do that ran into a problem i thought i got rid of the multiple pops while braking!! i dont get it all bushings are good new t/c rods and new coilovers sway bar front and back all calipers are good gonna change it to the z32 anyways but idk why these pops are happening!
TheRealNap0le0n
Car: 1998 q45
might be the pads moving or the calipers... make sure there are no shims or bolts missing.
michael_grigoras
1987 bmw 320i
1983 toyota starlet
1977 mercedes 240d
well picked up my calipers 30mm aluminum all 4 for 250 rebuilt so im happy with that having some trouble looking for the r32 e brake cables though
DET240SX
Car: 92 Hatchback S14 SR20DET, 89 Coupe SOHC KA24e(soon to be 1UZ), 01' 330CI
240life wrote:people say you need conversion lines, but I have used stock s13/14 lines with no issues, just remove the nipple off the caliper..it will work..trust me, also R32 e brake cables work with no mods, bolt right up to stock e brake mounting points.
Do you happen to have a pic to prove that? I know that the conversion line topic(z32 vs. R32 vs. R33 lines) seems to be the biggest bottle neck to this swap. It's been a couple of years since the post I suppose but...thanks
