Z32 Big brake kt pics
nsrZ32
Car: 90 Nissan 300ZX TT
78 Datsun 280Z
71 Datsun 521 Pickup
98 Nissan Sentra 2.0 SE
02 Nissan Altima 3.5 SE
01 Ford Focus S2
Here's a couple pictures of my custom big brake kit for my 300zx. I'm using 3000GT VR4 rotors (1.5" bigger diameter) and machined caliper relcation brackets. Stock calipers are amazing so they are being reused.
I had to trim the dust shield to allow the caliper to bolt up in its new location and because of the offset of my wheels I will have to run a small spacer. Just to be on the safe side, since I'm running a spacer, I'm ordering NISMO longer wheel hub studs.
Also, upon weighing the rotors, the stock sized 300zx rotor weighed in at 15.2lbs and the larger VR4 rotor also weighed 15.2lbs so there appears to be no added weight.
Here's a side by side shot of the brembo Z32 drilled and slotted stock rotors vs. brembo cross drilled and slotted VR4 rotors.(don't mind the minor surface rust, I haven't driven the car in a few months)
Stock sized rotor on car
Larger VR4 rotor on car
Caliper in new location on vr4 rotor
Comparison of stock sized brembos behind wheels vs 3000GT rotors behind wheels
I'll keep you updated once I pick up the spacers and longer studs.
