It's 16 gallons with a 3 gallon reserve on the 2+2, so 19, and 13 or 14 with a 3 gallon reserve on the 2 seater.
I'd agree with what Anton said about cats, O2 sensors, or TPS being the culprit. Perform the Mode II (Heated O2 sensor test) and see if the sensors are switching between lean and rich.
http://www.ttzd.com/tech/diagnostic/diagnostic.html
That's a good write-up. Also get a multimeter and test your TPS for proper voltage. Specs in EC section of FSM, can't remember off the top of my head, but should be somewhere around .5V.
If neither are failing, I'd say the cats would be the issue.
