V8NSIDE »
https://forums.nicoclub.com/v8nside-u43547.html
Sun Aug 27, 2006 5:13 pm
I have done some autocross before the swap and the car handle good. The main problem I had was the suspension, because of it being so old and worn, and the car just did not have the speed I wanted to get out of the corners. Now after the swap the car is awesome.Some recommendations: No matter what you get you are going to need aftermarket suspension, and probably some better brakes. Next to that, if you are getting a car that does lag in the hp department, at least try to get one that can go high in rpm, something above 7000. This will help you come out of corners and use the low gearing that most import sport cars have.Like some other members already mentioned, the 240’s and MR2’s are good cars, but so are 300z, RX7’s, 944’s, 325i, and I hate to say it but the Miata are all good cars and in you’re price range for a autocross car.
