z32 and maxima MAFS?
chester_ff7
Car: 1996 Nissan 240sx
ok i have been hearing a lot of things about the N60(maxima) MAFS. my question is the N60 a better mass air flow sensor the the MAFS that comes on the Z32? plase let me know... thanks!!
FUNGC
no Z32 came with the N62 mafs which is capable of more power than tha N60 mafs
chester_ff7
oh! cool, what about the Q45 MAFS? what size is that? and what size comes on the S13, and S14? i know that the s13, and s14 MAFS's are different, whats the size difference?
CleanSfourteen
Car: A cooler car than yours
N60 and N62 are the same size with different voltage outputs, Q45 is larger but they are all overkill for the S chassis.
The stock ka24de's MAF is extremely small, N60 is a cheap alternative to the overly popular N62 and Q45 MAFS. New they are all expensive, but for a used MAFS a N60 can be had for under 60 bucks. SAFC can straighten out the voltage settings, they are only slightly different from the 300zx's.
chester_ff7
"Q45 is larger but they are all overkill for the S chassis. " what do you mean? what if i could get a Q45 MAFS for free? would you recommand it? because my buddy has one, and he will give it to me.
CleanSfourteen
I wouldn't recommend going through the trouble for a N/A car, but as long as you correct the voltage and tune it properly you can use almost any MAF sensor.
