BlazingCopperZ »
https://forums.nicoclub.com/blazingcopperz-u138921.html
Tue Sep 08, 2009 11:40 am
So I have test fitted the VH in my Z, along with modifying the crossmember to fit the headers, built the motor mounts, and am 90% done with the rear sump oil pan, whoo-hoo. I am eventually going to start a thread with lots of pictures, along with my oil pan design.
[IMG][/IMG] [IMG][/IMG]
Over the weekend, I was able to do some measuring for the radiator and such, and ran into a few things that are worth asking. For those of you who have completed the swap, are there any who have the AC running? I measured about 4 1/8" between the VTC solenoid and where the front of the radiator will be. There seems to be very little room for the puller fan setup without pushing the radiator into the support like Superhatch did. On the other hand, if you put the fans in front, will there be sufficient airflow through the AC condenser? T45, do you have any issues with not having the stock condenser fan?
BTW, I found the button that allows you to search past the 365 days so I read all of the older post that answered most of my wiring questions, kinda makes me feel like an idiot Thanks
