Z32 5 lug & Brake Upgrade question...yes I searched already =) Easy Question
Luvs2slide
Car: 93 Nissan S13 Onevia
I read like 20 threads on the 5 lug and brake upgrade from a 300zx. I'm trying to figure all this out im having some difficulty. Im getting the rear hubs, rear calipers, e-brake line, and the MC. According to all the threads they should work perfectly with no modification. They will be from the 1990 NA Z32 (which has the 26mm AL rotor. Nothing really states in those threads if the front hubs will work. I understand the calipers will. Can the Front hubs work? What do I need if so? If not I will go S14, with upright and all. I do understand having to get aftermarket brake lines for the front. Sorry if this seems drawn out. I've did alot of research so far and starting to get confused. Please Clarify someone!!!
DRFT(kinda)
Car: 2005 Nissan Titan.
As far as I know the front hubs from a 300ZX do not work on a 240.
MagikDragon
Car: 1991 240SX, 1992 240SX, 1986 MB 190E 2.3-16
well heres a website that helped me out alot especially if you have an s14, but most everything is drawn out for you and the s13 is not much more difficult to understand. http://www.importnut.net
read that and if you are still confused let me know I can help.
180fan
Car: 89 fastback
rears get the backing plates all the way out to the rotors and you'll be set.
fronts, you'll need 5 lug conversion hubs. z32 hubs don't work.
Luvs2slide
awesome. Thanks for the replies. That clarifies everything.
