placham »
https://forums.nicoclub.com/placham-u38577.html
Sat Jun 27, 2009 8:19 pm
Thanks bro I all ready got this handled, fabed up some brackets from scap/spare parts I had laying around. Got the drums/rotors installed all is honkey-dory now.
Here are some pics I snaped while I was doing this, knew some one would probably wine that I didnt take pics.
Seen something similar on the forum one of the members was selling, so I figured I'll give it a shot, its towards end of week. Even if I would order something like this it would take few days to arrive, so I gave it a shot.
I'll make a brief description to go along with pics.
These were my first ones I made, or attempted was freehand formed. Kind of eyed balled and took few mesurements. Think they came out okay.
This started out from a L shaped beam/bar I picked up at Home Depot few weeks ago. Its a .25" thick steel L shaped beam was like 6feet long, coasted me about $12
I used old e-brake cables to make the holes in the brackets so it would be a good fit.
As you know e-brake cable has a dowel/centering pin where it bolts to body, well I didnt have any dowels or pins laying around. But I have a $hit load of loose bolts, so I choped of the heads from I think like 12mm bolts. I had a hole drilled through. I put a nut on one side so the choped off bolt would sit flush against the bracket. And I used my MIG welder to tack it into place on both sides. Then I grinded down one side where cable would go. And I ended up with something like above. They dont look pretty but their solid and get done what I need them to do.
For some reason the R33 e-brake cables were not long enough to reach the t-bracket when mounted in the stock S13 location. But the R33 cables are long enough, I have nice slack and bend going towards the back and to the sides. Their secured/bolted down onto the subframe like old ones were. I'm just glad I crossed this bridge.
And now I just have left bleed brakes, install wheels, and tighten my axle flange bolts down.
New wheel bearings, backing plates and R32/Z32 calipers
OOPs how did this get in there, check out my Cusco strut bar son.
That's it folks, thanks for comments, I wasnt sure if I was doing this right. Dont know if Z32 2+2 cable linkage is longer than R33 GTST, in which case it would allow mounting in stock location of e-brake cable on S13 or if my car is an odd ball.
