its all in the spoke design that determines what clears the z brakes. There are certain models of oem se s13 wheels that actually clear too. Meisters should clear if you get the ones with the low disk.
adrians_s13 wrote:its all in the spoke design that determines what clears the z brakes. There are certain models of oem se s13 wheels that actually clear too. Meisters should clear if you get the ones with the low disk.
You think so?It took me 3 tries to get 30mm rotors. They are all over EBay, and for some reason, that is the default rotor size at my local parts store.At least that WAS the case 2 years ago when I bought new rotors.
