So the handling in my new 1990 2+2 isnt BAD, but I am coming from a 1989 honda civic that had select bushings replaced with urethane, tokico shocks, h&r springs, upgraded to 4 wheel disc brakes, etc
So, the Z doesnt feel as good as the civic
I was thinking sway bars, so as to keep the ride quality but tighten up steering response and reduce body roll.
but which ones to go with?
I am reading that
rear
All 2+2=21mm
TT=26mm
Both fronts are 26.5mm for 2 seaters
All 2+2 fronts are 28mm
And I was thinking that a TT upgrade with urethane bushings would be a considerable upgrade till I read that. If it still will be, someone let me know. Rear only of course, with new bushings on the front.
The stillen is
front sway bar is 28mm and the rear is 21mm.
so the same size as mine but solid.
Whats the best / cheapest solution? Stillen sways? upgrade the rear to TT, replace bushings and add end links?
I have subframe spacers ready to go on now.
