Just finished putting it back together after hours of learning how it works. I got the engine up to temperature, opened the door that is accessible via the center council/radio removal via the diagnostics tool and I can clearly see the heater core. I used a laser digital thermometer and read the temperature on each horizontal bar of the heater core. The top 4 bars are all at 37C, the bottom 4 are at the ambient temperature of my a garage which is 10C today.
So I now think the heater core and AC core are the same unit, top is heat and bottom is AC. There must be a door/flap on the other side of the heater/AC core that directs air flow either to the top of the core or bottom and mine is stuck on the bottom. If anyone can confirm this is how it works I appreciate it.
If I am right, which motor/actuator controls that door/flap, where is it located, what is it called, can I remove it without taking out the dash and what is the part number?
Now if someone can tell me if I can manually move that door/flap to the upper section of the core and get heat until I am ready to take the dash out?
