Postby
evildky »
https://forums.nicoclub.com/evildky-u13100.htmlTue Dec 30, 2014 10:03 am
I split this post form the ancient post you replied to.
Could you first turn off the caps?
Secondly be more specific? Are you replacing a harness? are you doing an engine swap? Adding a romulator or piggyback? replacing the ecu with a stand alone?
Also you posted VG30ETT which isn't a stock option, are you twin turboing a VG30ET or did you omit the "D" in VG30DETT? or the most likely scenario did you add an extra "T" to VG30ET?
Postby
AZ-ZBum »
https://forums.nicoclub.com/az-zbum-u9212.htmlSat Jan 03, 2015 2:51 pm
angusyoung wrote:HAS ANYONE ON HERE WIRED A Z31 WITH A VG30ETT ENGINE HELP NEEDED NIGE ENGLAND
1. Don't type in all caps. It's considered yelling and rude.
2. Use punctuation. It helps understand when sentences end.
3. VG30ETT or VG30DETT? VERY different motors.
Postby
angusyoung »
https://forums.nicoclub.com/angusyoung-u241182.htmlTue Mar 17, 2015 10:42 am
Hi all ill try again i have a 1989 300zx single turbo. ive fitted a vg30dett engine also used the z32 transmission ecu and wire loom. the engine is fitted. im at the stage where im wireing .im trying to find out how and where each wire gose to. i belive there is about 11 cross conections but as the where im clueless .any help please nige
