z31 turbo upgrade
Discuss topics related to the VG and VE series engines.
Syntax360
Car: 1986 Nissan 300ZX Turbo
I am currently building my '88 n/a -> turbo conversion motor, and I want to get a t3/t04e slapped on before I put her back together. I was wondering if anyone could tell me a good a/r and trim for her. I plan on pushing 12psi or so off the t3/t04e and my power goal is 340whp. Thanks!
Und3rprshUr
Car: My 300Z
Stock fuel ?
if so you wont reach your goal-
go with a 57 trim t04e with a .63 housing and a stage 3 wheel if thats your ideal hp goal.
Syntax360
I was told that a walbro and an adjustable FPR should cut 12 pounds - what do you think? If I have to i'll buy the whole greddy emanage setup. I just didn't want to spend a grand on fuel management unless i had to. (btw, thanks for the reply - not enough of that happening this side of the board :-) )
Und3rprshUr
Car: My 300Z
fuel pump and a adj. fpr will be fine for stock injectors on 12lbs. but thats it-
Greddy e-manage won't work either.
with fpr fuel pump and a upgraded turbo you should see high 200 hp. and 3 somthing torque. .
whihc should net you low 13 sec time slips.
Syntax360
There's a lot of other stuff I have planned. A friend of mine was running 12.8 with half the mods I have planned and still using the T3, but he was also pushing 18 pounds through his. If it's not too much trouble, could ya explain why e-manage won't work? I have no first hand experience w/ fuel management systems (never had a car that warrented it 'till now :-) and I was under the impression those fuzzy logic piggy backs were pretty universal. Thanks again.
Syntax360
*bump* Und3rprshUr
Und3rprshUr
Car: My 300Z
Yea there pretty universal for ecu's that can think as uick as it can. lol
your ecu is a 8 bit unit. nothing will work beside hks afr and that requires additional parts to get it to work and is just a pain. the stock ecu does a good job of learning the car as to more fuel psi and etc.. i would throw on a fpr and set pressure and go from there lil increments with bc to see as far as you can go then back donw some.. also get a dyno run when you "think" it is safe boost level and check the a/f ratio i bet it will be lean. Your buddy was lucky. the stock injectors are 259cc so anything over 12 psi on stock regulator is too muhc. and with a fpr can only prolly bring the a/f ratio to correct at 12psi. more psi doesnt mean more power. just more heat. 18psi lean will run slower than 12-13 psi a/f corrected.
Syntax360
ya, he eventually killed her. such a shame too - beautiful car. i'm pretty set on 12 pounds max, stock boost daily, and maybe 10 sometimes - never more than 12.
"anything over 12 psi on stock regulator is too muhc." - so I wouldn't need new injectors or an adjustable FPR to pull 12 pounds outta the stock T3 safely? i'm really worried about the high compression my engine's running (a hair over 9:1 now that heads have been resurfaced) and I'll prolly get an alcohol injection kit w/ boost switch @ 10psi. I just can't justify buying a T3/T04E and never really putting it to good use. That money could go into getting a LSD or something.
Und3rprshUr
Car: My 300Z
Spend money on a nice fmic and a fpr. you'll be fine. always run 93 octane. don't boost over 10 with out a fmic.
Syntax360
roger that. thanks for all your help Und3rprshUr!
Return to “VG30 / VE30 Forum”
