Z31 turbo question
A home for 1983–1989 300ZX owners!
sttp01
I am pulling out the turbo from a z31 and I need to know if the internal wastegate is something I need to keep or can replace with an external? also having difficulty getting into the space for the bolt on the exhaust manifold any tips it is a wierd angle and very tight spot.
AZ-ZBum
Car: 05 Nissan Murano
84 Nissan 300ZX Z31 AE
88 Nissan 300ZX Z31 Vert
Depends on how much power you plan on making. How much power do you plan on making.
sttp01
well the fact of the matter is I am pulling it out of the car we bent the rod pretty bad get at the manifold bolts, so i was wondering if we could just do an after market wastegate. I plan to see if I can do a ka24det with the T3. Any and all help would be great, I dont know much about z cars.
AZ-ZBum
You can do whatever you want. A wastegate is a wastegate. But chances are, fixing the internal wastegate will be far cheaper and easier.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
replacing the actuator is a heck of a lot easier than running an external wastegate, if your up to adding the wastegate port and the additional piping by all means have at
sttp01
So I pullled the turbo, and recovered the internal wastegate, the rod has been bent pretty bad but I am sure I can twist it back into shape... we had to bend a lot of hoses and stuff to get it out of the z. We also used a shifter from a celica as a crow bar to pop off the steering knuckle (man we should have brought a hammer). Turbo has no shaft play or anything.
Return to “300ZX (Z31) Forum”
