z31 turbo on revhard?
chmercer
will this work? in stock form the compressor housing points in the wrong direction, so i clocked it down to where i could pipe my intercooler to it. I will be using an external wastegate so the actuator not bolting up is not a big deal. what i am mainly concerned with is the oil lines. will they work right, seeing as how the turbo is sideways, compared to how it is positioned on a z31?
thanks!
:: orion ::
Car: '96 240SX, with KA-T @ 12psi...
Oil inlet/oulet need to be straight up and down...
But you can clock the center section...just like clocking the compressor housing. Loosen the turbine housing, loosens the compressor housing....make the oil inlet point to the sky, and then tighten everything. Easy.
- Brian
