z31 throttle body
Wakkolio
Want some opinions if i should get one installed. The TB is 60mm versus the KA's at 50mm.
TrunkMonkey
Car: 2000 Lincoln Navigator
i could be wrong, but i don't think it'll bolt up to the KA's manifold.
-demetrius
far1002
Car: cars art
i think that the z31 throttle body is smaller than the ka's because i ve got an m30 and it has the same engine as the z31 and on the infinte forums they switch to the 240's throttle body because its bigger but they do bolt up as long as you have a ka24e
ziggy682
Car: 1991 240SX Turbo
far1002 wrote:i think that the z31 throttle body is smaller than the ka's because i ve got an m30 and it has the same engine as the z31 and on the infinte forums they switch to the 240's throttle body because its bigger but they do bolt up as long as you have a ka24e
I think a KA24DE throttle body is something like 70mm, but I don't know if it will bolt up.
black kat
yes, i do believe z31 users use the sohc ka TB. at least many of those with custom manifolds do.
dreamsOfSkylines
The ka24e and z31 are interchangeable, but the 240sx one is bigger. Many z31 owners use the 1990 240 TB.
Dattebayo
where did you get your info about 60mm? That puzzles me because i had a z31 for a while when i was younger, and all the info i got said to use the 1990 240sx TB, that it would "bolt right on" to the z31 mani and was a great deal bigger than the z31's. Maybe a z32 would be bigger, but i dont think it would bolt on at all.
Boostn
Woah, someone got some bad info.
Z31 300ZX Throttle Body = 52mmS13 240SX Throttle Body = 60mm
sultan
i have a spare tb i picked up at a junkyard, but it's from a Q45 and it's 85mm. i would bet it won't fit, but if you need bigger, it's much bigger.
Dattebayo
yeah somebody got it all backwards. But anyway i dont think that with our intake manifolds and everything that it really would be a great improvement (especially with a turbo) even if it was bigger.
Wakkolio
i think i got it backwards....i was commenting on what a friend here said.
Dattebayo
it would be nice if they made afetrmarket intake manifolds so we could actually have real use of bigger throttle bodies .
McAdam
Car: I like cars and my motorcycle. boats are fun too
Yup, someone gave him some bad info. I am into Z's as well as 240sx's. KA24E TB's are a bolt in perf upgrade for the Z cars. stock for the L28E's is 50mm, VG30E is like 52ish and the L28ET is 55mm I beleive. then your KA24E's are 60mm. if you put a KA24E TB on a L28E and just port match it to the manifold, it'll pick up roughly 10% hp at the wheels! kinda sick when you realize just how corked up that motor is....
McAdam
syka24et
Car: Turbo cars
Will a q45 TB with a custom manifold be advatages on a turbo app. I have one of these and know some one who could weld one up for me. Do you think this will kill all my low end power, i can live with a small lost but not an overkill any opinions?
